TwinTurbo.NET: Nissan 300ZX forum - Re: Sounds like the old PTU problem where it would
ZTom
on September 19, 2015 at 1:52 PM
posted by doug8867
on September 17, 2015 at 01:53 PM
I agree. Where the PTU is located it get heat from the engine and over time it will fail. I relocate my under the center nose panel next to the MAF.
Cars stalls when warm & wont turn over for 2 hrs after stall
MattMart1(NJ)
13:09:10 09/16/15
Low coolant can prevent hot starts, not sure about stalling. (n/m)
Schmeal (NV)
13:22:11 09/16/15
Did you call Z1? (n/m)
BannonZ
13:51:30 09/16/15
haz you czech'd da fuel pressurez? (n/m)
fuzzymonkey
14:02:04 09/16/15
2nd on fuel pressure check. Could be a bad fuel pump
ZXoltan
15:12:22 09/16/15
solved alot of issues on my old NA after replacing fuel pump
abozx
15:31:45 09/16/15
Re: solved alot of issues on my old NA after replacing fuel pump
MattMart1(NJ)
15:47:33 09/16/15
Yes that could be a PTU on the way out, or an electrical
ConVerTT
17:49:31 09/16/15
code 21 replaced PTU and all is well (n/m)
njz
14:12:58 09/18/15
Nice! Good thing the OP found you ! (n/m)
ConVerTT
20:53:57 09/18/15
matt give me a call
njz
15:48:23 09/16/15
Re: matt give me a call
MattMart1(NJ)
16:44:48 09/16/15
Re: Cars stalls when warm & wont turn over for 2 hrs after stall
Dsouthz32
22:29:49 09/16/15
doug8867
13:53:28 09/17/15
Re: Sounds like the old PTU problem where it would -
ZTom
13:52:36 09/19/15
Re: Re: Sounds like the old PTU problem where it would
TTkeeper
11:07:05 09/20/15
Re: Re: Re: Sounds like the old PTU problem where it would (n/m)
njz
16:49:42 09/21/15
